Hi all,
I built this shelving unit for my boat (which I live on) over the weekend as I’ve desperately been needing some more storage space.
I’m fairly pleased with how it turned out although this in addition to another small project I was working on has proven to me that there’s nothing straight on a boat! Or my boat, at least. Except for me. You seemingly can’t use anything to reference anything else against.
So, my first question is if you’re in a similar position, is there anything you can do to try and make stuff square?
I’ve not done too badly, and I suspect some of it is a case of rubbish measuring on my part (need to either learn to use a tape measure properly or find a better way of measuring stuff!). The shelves aren’t a million miles out but the gaps could be closed if I can find a way of making the main vertical board more securely fitted.
It looks as follows:
Annoyingly there is a gap at the top of the board but I’m past the point of no return so it’ll have to remain. I’m wondering how I can better secure this board down. I’m using these small angle braces (https://www.toolstation.com/angle-brace/p34919) to fix the board to the back wall, but that’s basically it. I’m thinking of getting a two sections of quadrant moulding to fit to either side of the board at the top so it’ll look a little smarter plus keep the board in place.
I was also toying with the idea of screwing the shelves onto the battens but not sure if that is a good idea or otherwise.
So basically, looking for tips on how I can secure the board in place better so I don’t end up with the shelves dropping down between their battens!
Cheers all and hope I’ve been clear enough!
![4277BEEA-07ED-43BA-9D40-B2A4AD7A264F.jpeg 4277BEEA-07ED-43BA-9D40-B2A4AD7A264F.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/68/68479-4277BEEA-07ED-43BA-9D40-B2A4AD7A264F.jpeg)
