I am just starting the process of planning a rebuild of my shed. I have a number of problems which I am aiming to fix over the summer, namely ingress of water, cold (very cold) floor, totally useless door and low eaves.
What I intend to do, after removing all of the tools is remove the shiplap from the outside of the walls and the insulation and cladding from inside. Then
Lift the existing chipboard off the wooden base. Lay some 1"-2" battening on the floor and fill with polystyrene. Replace the chipboard.
Remove the roof (its sagging anyway) and fix ladder frames around the top of the walls. Chop off the top of the gable end level with the new frames. Add rafters across the shed (only 8' wide) to form a new flat roof.
Reframe the doorway and replace the door with a domestic front door.
Clad the outside of the shed with plywood. Is 12mm enough? Cover the ply with breathable membrane. Replace the shiplap. Do I need a gap between the membrane and the shiplap?
Reboard and refelt the roof.
Replace the insulation and interior cladding.
One thing I would love to have is a small wood burning stove. Is this possible / sensible in a wooden shed and if so are there any consideration I need to look into?
So thats the plan beginning to take some shape. I would welcome any comments.
Bob
Bob
