A link to the Wolverine jig would have been handy, just to see what it consists of.
If you have a flat rest, first set the grind angle. I always mark the tool with a felt tip marker, offer the tool to the wheel which is slowly rotated upwards with the fingers. This leaves a bright mark where the wheel makes contact with the tool & adjustment to the table is made until it is correct.
Switch on, then line the skew up so that the cutting edge is ninety degrees to the wheel & without rocking (that's the hard part) gently push & pull the tool sideways as many times as is necessary - this may be just once if only a touch up is required.
Turn the tool over & repeat for the other side.
Contentious issue - Wipe of the wire edge by dragging both sides of the tool across your sleeve (for which SWMBO berates me - I say that's what working clothes are for
) a piece of rag or a piece of wood.
Some say not to bother as the first cut will remove it (with the possibility of leaving metal in the work), whilst others just throw the tool into a piece of wood as if it were an axe.
You takes your choice. :evil:
