Ttrees
Iroko loco!
Hello all
I've looked through a few pages here and not found results,so I thought I might as well ask...
Having watched a good few youtube videos, I am managing to properly get the sharpening of drill bits
under my belt.... however,
I am surprised not to stumble across the problems I have encountered.
I am not sure whats going on here, and am looking to find out what the problem is.
Having bought a box of Silverline blacksmiths drills and one or two extras I found them good initially.
I probably overheated these in the past, due to being afraid of grinding them down to nothing when practicing.
So I held it off, and slowly drilled the holes I needed taking hours ....
Recently I have been trying to drill a hole in 40mm thick stock that was welded to a thick plate.
I have been drilling out this hole to 22mm plus (damaged bit)
The hole has to be a tad less than my 24mm bit ...
it is for a sleeve on a motor shaft to fit into a pulley .
Anyway
I spent two hours... or probably far more than that drilling this hole
During this time I managed to get my sharpening skills down and experimented with angle changes,
and was highly critical of my results, so strived for perfection .
End result was very sharp cutting edges , correct relief ground in a single swooping facet .
Still no cutting !
I was going up the bits in stages successfully until I got up to about 16mm and then the cutting stopped.
I don't think the tempering was at fault here, as I managed to cut with an overheated bit from grinding
easily ...evident from the blueing on the edges ,
Plus wouldn't the edge get dull on a bit which was annealed ?
Maybe my 40mm stock got work hardened or changed temper ?
Or was it that I should not be drilling these holes in stages of 2mm at a time, and try and get the drill to
bite into more meat to self feed itself and cut more aggressively.
My bits remain sharp after this drilling ceased .
Could the flutes be the problem here ?
Thanks for any advice
Hope I can get some answers
Tom
Anyway
Still no cutting !
Tom
