syntec4
Hello all,
Well I have been told to not go back to lurkin. So I completed (almost) my first project(s) this weekend. That is if you don't count the bench I built first.
I wanted to try making something from hardwood and doing some dovetails and a few other joints. So I made a couple of little boxes for putting countersink bits and bit holders etc in.
I have not quite finished the oak box yet as I need to pick up some hinges and some sort of catch for the lid. I have not finished or sanded either of them yet. The finish you see is straight from the block plane.
Took me a while to get the dovetails fitting ok. Although I know that I can get them a bit tighter on my next project. The oak box has different joints on each corner, I know it looks a little odd but I need to try out different methods. It will only be used for screws and stuff anyway.
Some more pictures here if you care to look and make some comments, I could use some feedback.
Lee.http://homepage.ntlworld.com/lee_harrison944/First project/index.htm
