Hi Mark. The face book page is, Wooden crafts from Wales. I was disappointed with the Hegner. Where the slot is in the table the two halves of the table are at different levels so there is a step, which is annoying when cutting as I have to lift the wood over the step. Another problem is the speed control knob, it is loose and after half an hours cutting I have to turn it up to full speed again as it as work its way down. I am breaking blades like there is no tomorrow. I am cutting 18mm thick hardwood and its like watching paint dry as it is so slow, it only runs at 1450 SPM. I am using a 9 blade FD-UR now to cut the outside shape of some items.
I should be getting the Dewalt back later this week, It died a few weeks ago and is having a new motor fitted, it runs at 1750 SPM and flies through hardwood. When i get it back the Hegner is going back to be sorted and the table is being exchanged for the cast iron one. The Hegner is a good little saw but I feel it is only for light work. Its a joy making my puzzles on as I am only using 6mm birch ply. I really wanted the 22inch hegner but then its £1000. There does not seem to be any way of adjusting the tension, I think the tension is to tight and that is why I am breaking so many blades. The saw has the quick release tension lever and clamps etc. I can reduce the tension when I have a blade in by undoing the black knob at the back but when I put a new blade in I am back to square one as the tension lever will tension the blade as before.
