I am posting because when I was researching this ,I found this site really useful. So thanks to the previous posters.
I had a large project involving cutting a lot of mdf panels, the festool and makita , both of which I have worked with were out of my price range at the time.
I took a punt on the scheppach 55 and this is how I view it.
The construction is pretty sound, though I wonder how long the plastic adjusters for depth and angle will last.
Motor is powerful enough for mdf & ply ( not used it on kitchen worktops yet)
Supplied blade leaves marks on the end grain which suggests they are not as well engineered as the top makes, however this is a minor problem.
The splinter strip is not great, not a problem for mdf, and as per previous post can be replaced with a festool one.
There are adjusters to stop tipping on the saw for when you are cutting angles ( but if you hold the saw properly you won't need them)
I went for 2 1400 guide rails, however the joining strip is so tight, you have to hammer it in, and is hell to take apart again, so on reflection 1 rail would have been enough, as its relatively easy to put 3 marks on the board and slide the rail along.
So, if you want it to last, this is the type of tool that lives in the garage, and doesn't rattle about in the van.
But for £219.00 its well worth the money.
