Tenko
Hi, pretty new to this forum but decided to update my old 3" scrollsaw and bought the Scheppach 402 from Screwfix.
Expecting a reasonable machine, I was grossly dissapointed. Its c**p and tacky. It says on the box tool free blade changing, that only applies to pinned blades, pinnless blades require the use of an allen key. Not only that, but you have to remove some of the housing to access the bottom blade block, not good. The variable speed is not what I expected, its high or low, not much variety there. The table and insert are poor, the insert is about 1/16th inch lower than the table creating a lip which catches the wood.
I have 2 bandsaws and as said, an old 3" scrollsaw. The Scheppach is the only machine that goes walk about then turned on and wants to fall off the bench. Overall, not impressed one iota with the Sheppach.
On the plus side, while making a bench extension yesterday for the useless scrollsaw I used my cheap Aldi Router for the first time and was very impressed. It was the first time I've used a hand Router since my London college days and I was more than impressed with it.
Mick.
Mick.
