This question is prompted by a discussion in the Buying Advice / Tool Reviews section.
https://www.ukworkshop.co.uk/forums/view ... c&start=15
I have a 12-blade lawn scarifier driven by 1800W electric motor.
Unfortunately I have a rather uneven "lawn" and thus the effective depth of scarifing varies from place to place. In the extreme, when two or more wheels are in a low place, the blades try to cut very deep and the motor stalls.
Also, if I start the motor with the scarifier in the lowered position the same thing can happen so I always tip the machine back on its rear wheels when starting the motor and let it get up to speed.
In both cases, when the motor stalls the fuse can blow (16A) or, more often, the differential switch (earth leakage?) trips out.
I think the machine has an induction motor (when running freely it make a nice hum).
Is this behaviour typical of an induction motor or would the same thing happen with a universal one?
Isn't this a very bad design for a piece of equipment that, by definiton, is operating on an uneven surface?
Surely the machine should be protected against the high current caused by stalling?
Should I try and slacken off the belt drive so that it slips before the motor stalls?
