SAW FILES TESTS - 23 files tested by 3 experienced filers
FenceFurniture
29 Jun 2013
Sydney, Oz
Firstly, a huge thank you to the three testers (Peter, Mark and Ian) who gave a great deal of their time to make this possible. Ian in particular spent additional time marking out the saw plate scraps so that the other two could just hook straight into filing teeth.
PREAMBLE
The three testers all have different perspectives, and that is why I thought they would be a great mix.
Ian Wilkie (IanW) is virtually a professional Saw Maker (could easily be if he chose to – whenever he puts a batch up for sale they sell out within about 30 minutes, and he ends up with more backorders than he put out for sale). He has formed from scratch I’d guess thousands of teeth over the years, and sharpened countless more. Ian didn’t have to do a great deal of research – he has done so much saw filing that it is intuitive, and he has quite a pedigree when it comes to fine woodworking, going back at least a couple of previous generations of very talented chaps. His preference for gullets on finer toothed saws is for less-round and like everybody else, laments the passing of proper Saw Files. In contrast to the other two testers however, he is not a huge fan of the taper, and can take it or leave it (although we might just see about that when proper tapers make their long-awaited return).
Peter Evans (heavansabove) is a serious amateur woodworker and as a very active member of The Traditional Tools Group, he is no stranger to saw sharpening and rehabbing. He likes a fairly sharp gullet in his saws, and is a big fan of the proper taper file. Peter has contributed a great deal of research to this project, including vital information such as the 1942 Nicholson Catalogue which revealed that both Taper and Parallel files were popular choices at that time. Peter also uncovered various other aspects of saw files, such as how the edges of the files are formed before they are cut (they are flattened with a file – not rounded over or “radiused”, and the edges are cut before the faces are).
Mark Aylward (Claw Hama) is a professional woodworker and sculptor. He has been classically trained in the art of filing twice, in two apprenticeships, and so knows his way around a file. He had a strong influence from his father and grandfather who were both professionally involved with timber. It was Mark who was able to describe the function of the taper in a file, and this was a pivotal moment in this project. He also defined why the corners of the file are toothed beyond where the faces are toothed at the toe. We have had long verbal and written discussions throughout this project to date, and that has been of enormous value in bringing it to this point. He also spent many hours researched and digging for the truth. This is a man who likes his gullets a little bit more curved than the other two testers, and I have a feeling that this is because of the size and type of timber that he has worked with – often large slabs of nasty Aussie hardwood with big tooth saws, where a sharp gullet can cause a fracture, and possibly allow for less efficient ejection of dust than a curved gullet might. Mark can probably rightly claim to be the world’s biggest fan of the proper taper file!
The files selected for testing were primarily aimed at those used for saws of 10 ppi and finer. Certain brands, such as Nicholson “Taper” files and Vallorbe Needle files were not included because their current reputation for quality (or a serious lack of) is so well known as to not be worth determining. Some brands were not as well represented as others, and this was largely due to the deep suspicion that many of them come from the same factories and provenance. There was only a certain amount of files that could be purchased and have time from the testers devoted to them.
For larger toothed saws, although there were new teeth formed in saw plate samples, the main purpose was to determine the suitability of the files for sharpening. There is scope for two types of file for larger teeth – a coarser file for rough forming and rapid metal removal, to be followed by a finer file for final shaping and sharpening of the teeth. Finer teeth are much quicker to form and a fine tooth file should do this quickly and efficiently. Therefore the files aimed at these saws were required to be able to do both functions effectively.
Researching has involved many people both here and abroad. Countless websites have been studied and numerous historical publications have been read. However, in all the tens of thousands of words that have been read, there has been no mention whatsoever of the purpose of the taper, or what widths the various file sizes and categories have their edges ground to. This would indicate that the taper and edges were taken for granted as much as a file has to be made of steel and have teeth cut in it to function (although there is at least some information around on those last two aspects). To all those who have assisted in the research – my great thanks.
Citric Acid sharpening was performed on 6 files, and a duplicate untreated file was also included. The testers were asked to pay particular attention to the differences between each file in the various pairs. One of these pairs was the Japanese file, another was a French made Liogier, and the other four pairs were of Indian origin.
In three of the Indian pairs, the acid treated file was a poorer performer, and in one of them it was marginally better, but both files in this pair performed extremely poorly. The acid treated files broke more teeth than the other file almost universally.
In the Japanese pair the acid treated file scored better, but this would appear to be due to better corners on this file, rather than any improvement made by the acid bath.
In the French pair the untreated file scored marginally better than the treated file. Tester C scored the acid file better, but that was because it had a better shaped corner(the specific corner that he used), rather than any improvement made by the acid.
We can assume quite safely that the steel used in the Indian files is inferior to the Japanese and French steel (that’s the only reason they are being produced in India – to get a cheap file). It would appear that acid treatment of lesser quality steel has a greater detrimental impact on it than on better steel. The Japanese acid file scored better than its counterpart (but because of the corner, not the treatment) and the French acid file only scored marginally lower than its mate. In other words, in files of quality steel, the acid didn’t cause it to be a disaster, but equally, it did not aid performance.
In short, the Citric Acid treatment contributed nothing positive whatsoever, and seems to have a very bad effect on lesser quality steel. After I had treated the files I noticed that they felt much “grabbier” (sharper) to the skin, and under a loupe of 8x magnification the treated files looked MUCH sharper and cleaner. Encouraged as I was by this I kept the caveat that this must translate to improved performance, and it did not – quite the opposite.
This leads me to wonder about those who claim that their old files are much improved after an acid bath – are they just being fooled by the grabbiness on their skin (it is a very significant difference in feel)? I wonder if they have ever done any empirical comparisons, because the evidence from this test would appear to be incontrovertible, although the sample was fairly small to make a bold statement, I suppose. Six-nil is pretty convincing though. Perhaps the effect is less noticeable with Engineer’s files where there is not so much concentrated stress on the corners.
Whatever it is, there seems to be no point in putting saw files into an acid bath – it won’t improve the performance of a new file, quite the opposite in fact. For an old file – well, they are worn down and there is no substitute for missing steel! There may be some short term temporary benefit with an old file made from good steel, but that was not the object of this testing. One thing is absolute – the height of the teeth is reduced as the file wears down, and acid treatment can only make them shorter still, certainly not longer.
TESTING CRITERIA
All the labels and logos were ground off the files, and they were each given a unique number. In this way the tests were done “blind”, although files from the sub-continent just look like they are from there, so possibly not hard to work them out. The files were only tested at one tooth pitch, and we were trying to determine the maximum number ppi (i.e. finest tooth) that the files were capable of. Right at the outset, it was noted that none of the 4” DEST files would be capable of 16-19 ppi, and so they were moved into 15.5 ppi. Whilst one of them performed ok at 15.5 the real point is that they are all failures because they are not fit for purpose at their intended tooth pitch range of 15-19ppi.
The Liogier Needle file was supposed to be tested at 19 ppi, but there was a little confusion there, and it was run at 15.5. No matter, being a 3 Square Needle it should be quite capable of finer than 15.5 ppi.
SCORING
<6.5 – FAIL
6.5 to 7.4 – BEWARE, you may or may not get a good one, might be inconsistent within the file itself.
7.5 to 7.9 – PASSABLE, should be ok
8 to 8.9 – GOOD FILE, buy it
9 plus – DOESN’T MATTER, no file scored over 8.7
AND SO TO THE RESULTS
I’ll commence with the bottom line, which is a chart of which files can be used for the various ppi ranges, from those files that were tested.
As far as being able to just go out and buy files for any ppi saw from one trusted brand – FORGET IT! Liogier would be the safest bet here, with no failures, but we have previously known failures to have been delivered (suspect that there was a cockup with 4” ST being sent as 4” EST on one occasion).
BAHCO - The larger Bahco files performed very well, with two winners, but the 5” DEST failed (and I have read that many people complain of this with the smaller Bahcos). The Needle file, whilst it cut good teeth, looks like an expensive proposition due to durability issues. It is also a very short file at 140mm total length.
LIOGIER - Equal overall score to Bahco (actually 0.05 higher), with no failures, but plenty of room for improvement with consistency of edges, and of course the taper. As a brand, Liogier scored highest for the tooth shapes formed (the most important single factor), but was dragged back a bit by some rough action files. We know from previous experience that when a Liogier file is on its game, it is the Duck’s Nutz.
GROBET SWISS – only represented by two files that are “officially” from this brand, but Indian files overall were very well represented (by default). Pretty ordinary results, with no failures. Neither file gained a “BUY IT”, with one file managing to get a fourth preference.
PFERD - An enigma. One file was a clear winner, and one a clear loser. Balance that with the box of files (6” DEST) I purchased that had clearly seen a meltdown. Maybe just stay with the 5” DEST, and hope they are consistent.
F.DICK - Another enigma, probably due to poor quality control. 6” DEST actually scored the second highest overall of ALL files, but the brand was dragged right down by some other shockers.
GROBET USA – Like the G.Swiss, it had low representation (1) but in the company of plenty of fellow countrymen. A very poor result to be the last of the Indians….
Japanese - Not at all popular, and last behind the Indian contingent. Does Citric Acid help this file? Hard to say, but probably not. Subsequently noted that the teeth on this file are at 75° to the edge of the file, rather than the usual 60°. This will make it more difficult to push the file smoothly.
GENERAL OBSERVATIONS
  • 1. Of the 10 files that make it to the recommended list, only 2 are from India, the rest are European.
    2. There are no 4” DEST files available that are fit for purpose.
    3. There are only a couple of files for use on 12 to 15.5 ppi saw
    4. There is a better number of files for 7 to 11 ppi
    5. <7 ppi should be no problem, but only two files tested for that range
    6. No file of any size had a correct taper, and it became even more apparent to two testers just how important the taper is (for constant pressure). The most experienced tester is not fussed about the taper, and that is consistent with all that has been discussed - experience will allow for a parallel file to be used, and perhaps even preferred (and let’s face it, these are all virtually parallel files)
Stunning amount of work. That's dedication for you!
I guess the only conclusion we can come to is that a better, more consistent saw file is needed in all sizes.
Thank you for taking all the time and the trouble.
If, as I have read, some manufacturers are making files of low grade steel which is then case-hardened, then
is there not a possibility that the citric acid treatment would eat through the the hardened layer into the
softer core of such files?
Surprised there has been such disregard to this post.
Next time FF you'll have to do a real in depth study on sharpening techniques. You'll be inundated with responses. You'll even get postings complaining about people complaining about posting on sharpening techniques.
Thank you to all concerned for the considerable time and effort that has gone into this study. I have passed the details on to our Bahco representative who has in turn passed them on at a recent meeting held at the file factory in Portugal.
I don't know about any of the other manufacturers, and I can't make any promises, but Bahco are certainly listening to what you have to say - which for a company of their size is pretty impressive.
That's a bit unfair, Mignal. There's a lot of information in that post and it will take time to digest. But at a quick glance it looks like an excellent study and very worthwhile - let's hope file manufacturers take note.
Cheers :wink:
Paul
Not sure. It had some 220 views and 2 replies including mine. Of course if the subject had been sharpening the ratio would have been 2 views and 220 replies. :shock:
Anyway, it's good to hear that Bahco are listening. I predict that the other manufacturers will do so as well. It's no longer a race to the bottom, it's a race to the top.
I don't think so Limey. If a CA bath of just a few hours was able to do that then that would only mean that the case hardening was perhaps a few microns thin, and I wouldn't think that would be possible.
¿Que?
Not a chance - I know when I'm well off.
The Acid testing was just a side issue: included because it was a good opportunity to myth bust it or not. Not sure if anyone has ever done empirical tests with attempting to "sharpen" new files or not before, but quite clearly the results show that if it's performed on low grade steel then it's detrimental, and renders a bad file useless (if it wasn't already). The other point is that even with files of good steel (that actually have a Chromium content, as saw files should) then there is no benefit - it just may not clobber the file altogether.
In other words, acid sharpening of new saw files is a WOFTAM, and I will not be doing any more research on this aspect.
I'd just always assumed a saw file was a saw file - how wrong was I :lol: with all the research you've done i'd say this is the most definitive guide to saw files ever - thankyou ;) ive got a veritas dovetail saw and always try to limit the use- through fear of not being able to sharpen it. Atleast now I can greatly improve the odds buy getting a file that's proven to be a good performer- thanks again.
Sent from my GT-I9300
I just wanted to say how deeply impressed I am by how thorough you've been with the testing and results analysis - anything less would not be good enough of course, but I am genuinely in awe - your family and friends will be really happy once it's all over!
Cheerio,
Carl
