A
Anonymous
Guest
Well, I often wonder about the sage advice offered down from people who have years of experience and accumulated knowledge.
The placing of the hand plane on its side etc. is clearly one that was recently discussed.
Another is the idea that one should set the height of a table saw blade just above (6mm or so) the workpiece height.
Anyone know why this is recommended?
I suspect is stems from the days where there were no crown guards and a low blade presents less danger if one should reach across. Or maybe there is some idea that it reduces kickback is the riving knife is missing?
Modern saws in the UK have both safety features as standard.
The thing is, that after much table saw use, i find that a high blade (maybe 40mm above the top of the wood) works best in 2 ways. First of all, the sawdust is dragged down into the cabinet and sucked away rather than being squirted out of the back of the saw and also i get a better quality finish on the cut.
What say you?
What say you?
