zambezi":370ynqa3 said:Not so much the dust but the load on the shaft/bearings. When you are cutting with the router it is normally done in small amounts and the cutter should cut the wood as it is fed through, which will naturally load the shaft/bearings. Sanding could be a higher load (in my head anyway), which is why I think it will be ok for light use.
I would be inclined to try and support the top of the bobbin, maybe with a bearing running on a support on the fence/table (similar to a router cutter with a bearing). That way you won't get all the load twisting unevenly through the routers bearings/bushes.
PS I have a habit of over engineering things :wink:
