CWatters
It can be quite hard gluing rods into blind holes. The epoxy can form a seal. You push the rod in compressing the air which then pushes the rod out again. Dril some tiny holes into the blind end to let the air out. Some epoxy will also come out of those holes so take care not to get it everywhere
Another method is to make the rods a tighter fit, assemble without glue then drip low viscosity super glue into the air holes. The danger with this is that super glue can sometimes wick a long way through the grain causing marks.
