woodbloke
The issue of shrinkage here is important. Both sets of rods would look good but only the ones parallel to the main axis of the table need be glued each end. As others have said, the steel rods going into the shorter axis need to be in overlong holes and glued in one part only. I might do it by gluing on the outside piece of iroko on the leg after the steel pins have been inserted (and glued into the beech core) The problem with doing it this way is that it might be a tad awkward to cramp together and would be very 'ard to clean up the final joint line. However if you made all three sections of the leg dry and cleaned them up, glued the two inner ones and located the outer one with some cut-off panel pins it ought :roll: :wink: to go together...needs a lot of careful thought to work out just how you're going to do it before you even attempt it and if I were you I'd have a dummy run on the leg assembly using a bit of pine. If you get it right, it'll be a nice piece. I also recommend that you try and get hold of some chrome steel (or stainless) as mild steel 'ordinaire' is going to go a bit dull - Rob
