I am in the process of learning woodwork and so am revamping the garage, and I am becoming obsessed with sucking up as much sawdust as possible from my machines!
Due to little space I don't have dedicated space for all the machines I have so far, so I was planning on running the sucky system around the top of the walls and down to somewhere near bench height in 2 or 3 workstation positions, and from there be able to connect smaller hose to whatever piece of kit I am using at the time (eg sander, jigsaw, mitre saw etc)
I have a workshop vac which is pretty sucky and has 100mm flexy pipe hanging out the back of it. Is it best to run as much as possible in the 100mm, stepping down to say a 40 or 50mm pipe to go to the machines? Does it matter where the blast gates sit between the main pipe and the machine? Can I use just 100mm waste pipe from the local shed or do I have to fork out on something even dearer from Axminster or similar?
Thanks.
Thanks.
