Is this necessary if you do the coatings all in one go?
Thing is, this is the part of finishing that I loathe - invariably I rub a coat down and then agonise over whether it's done enough. Then I usually take into it again and overdo it - sanding through in places. I've grown up with boats and so am always having to coat something with yacht varnish. Although things were different in the past most yacht varnishs are now polyurethanes. However, I've always rubbed down (the surface, not me) between coats of this stuff and now I've just read that there's no need to if the following coat is applied within a week.
Apparently, the solvent in poly softens the recently applied coat beneath and the two layers sort of 'melt' into each other. So rubbing down is pointless provided you varnish again soon enough. Is this really the case or has some lazy charlatan propagated this idea as yet another half-baked labour saving manoeuvre? It's just that as a lazy charlatan I've a number of things that need coating and would love to bypass the rubbing down bit. But I don't want to see the varnish delaminate in about a years time.
Finally, regardless of whether this melding of coats into each other occurs in polys or not, are there any other finishes where this happens? I'm keen to know of other occasions where I can avoid the rubbing back hassle. :?
