krismusic
I am making some small boxes from Birch Ply. I intend to rebate the ends of the sides. In the past I have used a radial arm saw to trench them out. This works quite well but does leave slight marks from the kerf of the saw blade. I assume that a better way would be to use a router in a table but I suspect that I would have problems with the router tearing the ply at the end of the cuts. The sides are rebated before the ends, so using scrap as a run off is not an option as far as I can see. Any advice / opinions much appreciated.
