RogerS
Itchy fingers perhaps but for the last six/seven months I've been mulling over various 'deficiencies' in my workshop. Most of my work seems seems to be on the large side...so I spend a lot of time with roller stands on long stock.
Conclusions so far ....
Table saw...Ryobi...fence challenged. Ability to cut large stock...ditto.
Router table...Ryobi cheapie combo....repeatability limitations...too small..fence ..a bit iffy ..OK but can do better... .so inspired by the varous homemade tables on the forum been thinking of going down that route. Triton router...has to be...means you don't need to spend funds on some form of lift plus ease of changing bits plus lots of other benefits.
Common deficiencies...fence and real-estate. So looking at Incra led me on to this
which seemed to meet some of my needs.
But then I looked at the orientation of the router end..which seems to me to be 90degrees out. Surely you'd want to have it so you could run long stock from right to left ...down that long axis? The way they have it limits real-estate for the router and back to fiddling with roller stands again for long stock...which is what I'm trying to avoid.
So a question for the Incra owners is...is there any way to rotate things by 90 degrees?
All suggestions very welcome as I'm running around in circles at the moment.
