So I had this (incomplete) router table for a while
...but as it is quite bulky, and my new workshop/shed is tiny, I needed a new plan that takes up less footprint, so came up with this design:
New footprint 600 x 350, and a bit storage compartment as well as other storage spaces.
So, as I had OSB left from the inside cladding of the shed (bought a sheet too much!) started by breaking it down
Quick check that I had the parts I needed
And on to routing shallow (5mm) dado's to easy the assembly
Which worked out quite well!
Started dry assembly, just to be sure I didn't mess up
And checked that the shortened top (was 700mm, now 600mm) fit as expected
Then continued with the dry assembly after I finished all the remaining dado's
Before gluing and screwing, I (luckily) remembered to add the rails for the bit shelves
And as there is a 10 image limit, will continue in the next post
