I am trying to build a roof lantern for my extension and am struggling with the hip rafters. I have constructed the cill and put a ring beam on top with a 25 degree bevel the same pitch as the roof. I have bevelled the ridge with a 25 degree bevel on both sides and i have placed some temporary timbers at 25 degrees to get the correct height of the ridge. My thoughts were to now construct the jack rafters and leave the ridge overlong at present. I have tried to cut the hips using a roofmaster square the hips are mitred together where they meet at the top and then are plumb cut as they meet the ridge. Where the ring beam meets the angle is not 25 degrees it is more like 18 degrees. I am cutting the hips on a table saw with a slider and to get the mitre for where the hips meet i am seting the fence to 45 degrees and the blade to 18 degrees which seems to work. To get the plumb cut i made up the hip and made a plumb line square from the ridge which doesn't relate to the plumb cut indicated by the roofing square. I now have a number of questions should i be setting the roofing square to 25 degrees for the common rafters and use that position for the hips or should it be reset to 25 for the hip. i need to bevel the hip rafter both sides should the bevel be 25 degrees or 18 and finally when i cut the hips to length how do i make the plumb cut can i rest the hip above the ring beam and above the ridge take a line up from the inside of the ring beam or will this make the hips either too long or too short when it moves downwards
i apologise for the ramble it is difficult to explain so here are a few photos
