dickm":1impdjmr said:Chas
Does reversing via the inverter do a soft slow down/soft reverse ramp up? If not, is flicking the reverse switch while the machine is rotating likely to cause problems. (I've no idea, but was thinking of the problems that can occur with the Dewhirst reversing switch on a ML&/Super 7)
Not a major problem, normal practise is to drill and tap the rear flange of the chuck to take a 5mm hex headed screw that can clamp on the spindle at the rear of the nose thread.nthomas":zu19h9iu said:....Never thought of chuck unscrewing,has put me off idea of reversing the lathe slightly.....
nanscombe":396s20so said:Sorry, I'll admit up front that I don't know a great deal about lathes, but is it not practical to work on the piece from the other side of the lathe so the piece appears to revolving in the opposite direction?
