Replacing a Thor mallet face
DTR
11 Mar 2011
Essex
Greetings all,
Some time ago I picked up this Thor hammer with rawhide faces:
(it's somewhat cleaner now)
I want to replace one of the rawhide faces with a hardwood face for chiselling duties. I'll be using iroko for the face as it's the most suitable wood I've got lying around. The sockets in the mallet head are around 30mm diameter and 10mm deep, and they are slightly dovetail shaped. What would be the best way of securing the new face?
If you're not bothered about keeping it all original, I'd suggest drilling through from top to bottom and fitting a stainless roll pin.
I'd clean up the rawhide faces and keep them. They will be far kinder to the ends of your chisels than a hardwood. In fact, I have a Veritas Cabinetmakers mallet and have covered the wooden ends with horse butt leather. I also have a Thor, but that has plastic ends. The Verutas and the Thor are a similar size and weight.
Regards from Perth
Derek
That was the first option I was considering.
wizard":2m9lir63 said:
Glue and press it in
... or this. The original rawhide was just pressed in, but the rawhide has the benefit of expanding into the dovetail.
Most mallets are made of hardwood, no? I've tried using the original rawhide and it just deformed. The rawhide is great for knocking a joint together though.
Hi
I'd go for hot melt glue. The face will work loose on a roll pin as a result of the impacts and it will become an annoyance.
Regards Mick
