Doug71
I have the bottom of an external door surround to repair, there are a few bits to sort out but it's basically mitring a new skirting round the bottom of the fluted pillars (pilasters?). The skirting is about 13" high, the house is listed.
The old (not original) skirting sat on the stone step and had rotted badly, when I removed the skirting behind it there was lots of wildlife, slugs, woodlice etc and everything was very damp.
I am building up the new skirting from Accoya and Tricoya but do I leave a gap under it so it can't soak up moisture and will get some air behind it or do I seal round the bottom? At the moment it is all open so it can dry out.
I have done both ways in the past, to the floor would look better in this situation but not sure if the sealed box it creates behind it is making the whole damp thing worse.
Just wondered how others might do it?
Thanks, Doug
Thanks, Doug
