harvestbarn
What is the safest way to remove a small amount of surface rust on a high quality measuring combination set?
matthewwh":1exkj0x3 said:Restore Gel
Completely non-abrasive and Ph neutral, so no effect at all on the remaining good metal and all of the accuracy that is left in the instrument is retained.
harvestbarn":23mdbs35 said:What is the safest way to remove a small amount of surface rust on a high quality measuring combination set?
woodpig":3eron6ls said:Battery charger and a solution of washing soda works well.
... but then it's not going to be precision with the rust on it and as electrolysis only removes rust no further harm is done. At least it'll look betterbugbear":ld0yhs1f said:woodpig":ld0yhs1f said:Battery charger and a solution of washing soda works well.
Yikes - if a precision item has enough rust to need electrolysis, it might be rust free afterwards, but it won't be precision!
BugBear
custard":31mix67g said:Mathew, that looks interesting. Have you tried it, does it do what it says on the tin?
