Boothie14
I am getting some AI bevel edged chisels for xmas,however i would like to regrind the angle to around 30? degrees to optimise for more chopping cuts-2 degrees is more for paring i thinks.My question is is the steel soft enough to do this on a course oilstone,or should I use a grinder with a white wheel?Also Is 30 degrees the right angle,bearing in mind its with a mico bevel of about 2 degrees?
