MattRoberts
Hi all,
I finally managed to pick up a record 52 1/2 vice for £50 - hopefully a decent deal.
After freeing it up with some wd40, it seems to work great - including the quick release.
I know we have some great tool restorers on here, so I just wanted to sense check my approach.
I'm currently letting it bathe in a generous coating of wd40. My plan is to then use a steel wire brush with generous amounts of wd40 to remove all of the surface rust and clean it up. I assume the wire brush won't be too harsh on it? I have a brass brush if so.
I've seen people using vinegar baths - would that be better?
One it's clean metal again, it's there a specific paint I should use?
Thanks in advance
Thanks in advance
