journeyman
Does anyone own the Record Power SS16V 400mm Scroll Saw. If so, would you recommend it and does it take plain end blades. My friend wants an entry level saw but money is tight.
Mick
Mick
Jwrhold":1v4fbqar said:Well, I have just had my first efforts at scroll sawing, and in a week I have owned two Record Ssv16, and have taken them both back to the retailer. Each one after about 5 hours use packed up. In both cases, I was cutting 1/2" MDF and it just stopped. The motor was running, but the blade mechanism had failed. I fonud a bush in the bottom of the unit, and clearly the unit has shaken itself to bits or just sheared off. Probably fixable, but not wanting to void my warranty I took the first one back for a replacement, and the second one back for a refund.
My opinion based on this experience would be to avoid Record scroll saws.
Also, on the second one I bought, the blower didn't work, so I fixed that, and also the hold down foot was useless. Tended to jam the wood on tightening.
Disappointing to say the least.
