My new 4 tpi skip tooth Axcaliber blade has been annoying me every time I used the bandsaw today. I noticed it was making a loud "tick tick" sound when I was feeding timber through so I had a look. There is an indentation where the blade was welded, and also it seems to have been welded a little "off" if you know what I mean. I do remember it making a little noise before, but today it was on another level. I need a quality blade I think!
I'm assuming this is what has been the source of irritation each time the blade touched the thrust bearings. It was also wobbling back and forth when viewed from the side while running.
I'm sure this isn't conducive at all to getting good results.
I was wondering if there was a particular blade that was well thought of. I read a few mentions of Dragon blades on the forum and might give one a go unless there is something better. Come to think of it, I could actually use a couple of blades, one for ripping and one for finer work.
As some of you will know, I'm new to the bandsaw and I'd really appreciate some advice. It has gotten a fair bit of use over the past couple of days, but I'm disappointed with the blade I bought. I'm sure it isn't doing my bearings any good, not to mention that fact that it is damn annoying.
On another note, is it the done thing to reduce the tension on the bandsaw when not in use or is it safe enough to leave it?
Thank's
Michael
Thank's
Michael
