FalconFlyer
Hi all,
Newbie/amateur needing help please!
I'm restoring a Classic shape Range Rover and was thinking I would try to re-veneer the centre console area myself. However, having now removed said piece of trim, it appears that the plywood underneath has blown/expanded causing the top surface to split. I would appreciate some advice here....can I try to re-glue and flatten the top layer of ply, or maybe even try to remove the damaged layer(s) and then veneer on top?
