Hi,
I have a small cnc router with a vacuum table (600mm x 400mm approx) and I need a vacuum pump for it. Until now I've been using an old vacuum cleaner, but it's just given up - burned out due to the lack of airflow I think. The vacuum cleaner was just about adequate, but I'd like to replace it with something more powerful. The problem is that I'm not sure what type of pump would be best or what pressure & volume would be required. Also the pumps I have seen are mainly rather expensive.
I'd be very grateful for any advice on what type of pump I need - I'm looking for the lowest cost option that will work. I did read an old post about using an old freezer compressor - would that work for this application?
Thanks,
Richard.
Thanks,
Richard.
