billw
The Tattooed One
Sorry. Another one!
This one moved me up a gear, as it involved dovetails and mitre joints. I haven't done a dovetail since I was in school. It was also my first opportunity to test out one of the mitre jigs on my new shooting board. Also the aim of this jig is to ensure that the two pieces to be dovetailed are marked up at 90 degrees across all 3 axes, so it needed to be pretty accurate. I used up some more of my European walnut stocks on this one as I had one board that would make the main components with little work, and I could take a slice off another for the fence.
Some clever sod somewhere designed this jig with dovetails in, which obviously had to be done without the benefit of a jig! Since getting components to be exactly 90 degrees to each other was the vital element, I suspected that there might well be some gaps along the way.
I've posted pics of this elsewhere so I'll skip quickly through the early stages. Here's a few shots of the dovetails being cut and fitted. That Veritas dovetail saw is insanely good, although I confess I say that with very little to reference it to.
The clamps in the last photo are attached to a plastic 90 degree jig to ensure that the two pieces are glued at the correct angle as opposed to the one that the dovetails would have created, which unsurprisingly wasn't going to be 90 degrees. This means there's some gaps around the dovetails that wouldn't be present had I not been overly bothered about the angles, but so be it. Indeed the same issue arose about the tails and pins sitting flush to each other, but I could plane the finished article to resolve this - obviously without planing so much that the faces were no longer at 90 degrees!
Second stage was to create the fence. It's technically going on the right-hand side since I'm left-handed and prefer to keep that side free, but I could simply flip it so the fence was on the left if need be by making the horizontal face the vertical one.
The fence was cut and planed, and then I marked out the two 45 degree angles, rough cut them and got to work with the shooting board.
The large gap between plane and board is because there's a lip to stop the blade cutting into the face even when fully extended. The plane leans slightly away, but luckily well within the adjustment parameters of the plane so the blade can be set at a right angle. I use a Stanley No 5. on the board most of the time, but here I'm using a No. 3.
Once both pieces were done, it was the moment of truth.
Not bad! Note that what looks like a gap in the first photo is actually partially a gap and partially shadow, as the face wasn't completely flat and there's about a 0.5mm difference. The other side is completely spot on, so that will be the one that goes against the board.
Final job of the day was to glue the fence to the board, making sure the fence is sitting at 90 degree angles.
Final jobs will be to tidy up the boards, perhaps trim off the ends of the faces as they're longer than the fences, and triple check all the angles. I'll apply some finish, probably Osmo Polyx again, and then make a test set of dovetails. Obviously the jig won't help with my sawing and chiselling skills, but at least I can't blame alignment!
![IMG_8732.jpg IMG_8732.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/71/71998-IMG-8732.jpg)
![IMG_8735.jpg IMG_8735.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/71/71999-IMG-8735.jpg)
![IMG_8738.jpg IMG_8738.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/72/72000-IMG-8738.jpg)
![IMG_8757.jpg IMG_8757.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/72/72001-IMG-8757.jpg)
![IMG_8759.jpg IMG_8759.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/72/72002-IMG-8759.jpg)
![IMG_8762.jpg IMG_8762.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/72/72003-IMG-8762.jpg)
![IMG_8766.jpg IMG_8766.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/72/72004-IMG-8766.jpg)
