pre cat lacquer over water based eggshell?????
kostello
11 Feb 2011
slightly more sunny flackwell heath
so........................
when i built my kitchen i painted the cabinets in water based eggshell..........
which hasn't worn very well....
i have since discovered the joys of pre cat lacquer and a hvlp spray gun.
can i just go over the eggshell with the lacquer???
fortunately i nver got around to making the doors and drawerr fronts so these won't be a problem... i just need to do the carcasses....
can you put pre cat on with a small roller???
sasha
Simple answer is no! It depends on how long the water based paint has been on but I wouldn't like to try it myself. You can use a roller for the AC but you will need to work fast. HTH. :wink:
