Hi folks,
My AX10 came with a 16amp plug. The reviews stated that with a plug converter, everything would be fine....
When i press the 'on' button, sometimes it doesnt start and i need to hold the button on until the motor gets up to speed, then all is fine. The duration of time i need to hold the button on varies.
I may be 'inventing' this situation, but it appears that it starts fine when cold, but as i use it (even just a couple cuts) i need to hold the button on for longer and longer until it will stay running.
I called axminster and they told me that the reason this is happening is because i am running it off a 13amp socket and not a 16amp. Would this be right? In my simple mind, if the 13 amp fuse is not blowing, then it cant be demanding 16 amps..... I do wonder if (and may be totally wrong here) the reason it doesnt start after a few uses is because the cables are warming up and not able to deliver?
Thoughts appreciated.
