I have been given a Titan power planer. However I am not sure if the adjustment is accurate. The fixed sole plate looks ok - however! when the adjuster is set to zero the front plate(adjusting plate) is not in a line with the fixed plate. At the end next to the cutter it looks ok but at the front of the plate there appears to be a run of about 2-3mm. This run arrears to be consistent throughout the adjustment range.
