Reggie
Hi all, in the list of things that have been donated to me, one of them is a power devil PDW 5047CPM compound mitre saw with a push action on it.
Overall it's pretty well looked after apart from a cracked handle on the bit that tightens up the mechanism for setting the blade at an angle, however this doesn't affect the function of the handle.
I haven't measured yet but it looks like I should be able to do about an 18" wide cut with it, it's got a 10" blade with 80 teeth (need to double check that), behind where the blade mechanism hinges for you to move it up and down when you cut, there is a small piece of metal that is bolted down on the back of the hinge housing, it looks like it might be for adjusting the depth of cut, could someone confirm this for me?
Also, it seems like it should be a useful thing but when I tried it out, it did work to limit the travel of the blade depth but didn't seem particularly practical, do you guys use that feature at all on your compound mitre saws?
