Hi,
I bought one of these intending to make a router table insert but decided it was too flexible material http://www.ebay.co.uk/itm/Kitchen-Chopp ... 259ff8ca12
So instead i have made a table top for my scrollsaw its lovely material with a nice smooth surface so work will slide nicely, just drilled a 3mm hole and attached it using some double sided sticky tape (won't damage the saw) its 12mm thick and is available in other colours but white is ideal as it shows the pencil lines up. Also attached a small LED clip on light on my Dremel stand next to the saw and does a nice job lighting my work.
Brian
ps I haven't cut my chopping board as it fits the length ok and don't mind the overhang as its more room for work piece.
Brian
