Polycut 3 owners UK spec AEG
user 42626
25 Jul 2023
As many of you know I refurbish Hegners.
I have a Polycut 3 but it's motor data plate is lost, I need some pictures from fellow owners of the motor data plate as it will help with motor capacitance values. Must be a UK spec Polycut 3, 240v approx 1980 to 2000 vintage.
This P3 tests at 5.8uf but ideally I would like to know the data value on other P3 saws.
Many thanks
Here's an example
If I'm reading that correct the first picture was 2006 model and second picture is the 1984 one.
Two different measures of capacitance 8uf and 6uf.
I bought this one second hand and motor data plate and model serial number info was all missing.
It's tested as 5.8uf and working ok. I guess I'll fit a 6uf when it fails as it's safer than going past the rated threshold
Thanks for your help
Regards
Carl
