Phil Pascoe
I've a small roof to do on a new man cave I'm using polycarb sheets - is it ok to drill the holes or (as instinct tells me) should I burn them?
phil.p":cweqcc52 said:I'm using polycarb sheets - is it ok to drill the holes or (as instinct tells me) should I burn them?
phil.p":4xvoyhvs said:Thanks everyone. Mind made up .
How are you going to seal the joins Phil?phil.p":2zf6hblz said:It's nothing special, it's 27' x 5' - I'm roofing over the passage up the side of the bungalow. It's not for woodworking or indeed everyday use, but it'll give me an 8' metalworking bench and loads of shelf space. It'll free up loads of space in the single garage that houses my workbench and lathe.
Ah ok Phil, didn't realise it was corrugated you were talking about, from memory it's only about 1 mm thick so dead easy to drill and you'll be using proprietory fixings anyway as they fix at the highest point of the corrugations. You could burn holes in that but I still wouldnt recommend it as polycarb is UV treated on the top side and burning will affect that causing early failure.phil.p":1w056m3v said:It's east facing so takes next to no weather. I've allowed a 6" overlap (3"corrugation, and 9" on the ends) and I'm open to suggestions as to what to seal it to the wall with. We're spending money we haven't got atm, so I'm reluctant to spend nearly as much on the flashing as the sheets.
