You know the organiser boxes like this?
http://www.stanleyworks.co.uk/Tool+...Pro+Organizer/SkuDetail.ctlg?ObjectID=92-749#
Well, I have a stack of them and have got fed up with lifting out the top 4 to get to the 5th one down as the one I want to get a single screw from is never at the top of the pile.
What I need is an Organiser Organiser, how ironic!
I'm going to make a plywood unit using carcass joinery and am torn between using 'Mitre Lock' or 'Rabbet and Dado' for the corners, Tage Frid recommends using 'tongue and groove'to join the shelves to the carcass, does anyone have an opinion on whether the T&G in 12mm WBP will support the weight of one of these boxes loaded to the gunwales with fixings? He is very clearly against housing the shelves completely as there will be no shoulder acting against the side.
For the back should I rabbet or groove? and what would be the best material, hardboard or 3mm MDF.
I've just reread my ramble and think a summary is needed
1) 12mm Plywood carcass corners - Mitre Lock or Rabbet and Dado
2) Joining the shelf to the carcass - will T&G be strong enough
3) Material for the back - hardboard or 3mm MDF
4) Joining the back - rabbet or groove
