Chunky Monkey
Hi all,
Wickes currently have some deals on 8' x 4' sheets of ply when you buy 3 or more, making them just over £20 per sheet (12mm) so I've decided to finally ply line my workshop. The ply will be screwed to the studs at 600mm centres. I would like to then screw my wall mounted cupboards directly to the ply without having to fit suitably placed noggins behind it. My question are:
i) Will 12mm be sufficient to retain the cupboard screws or should I consider 18mm?
ii) Will there be any difference in the ability to hold a screw between their structural spruce ply and their hardwood ply.
Jon
Jon
