mudman
- Joined
- 11 Feb 2004
- Messages
- 993
- Reaction score
- 98
Hi all,
I'd be interested in people's opinions on this.
I'm planning to build my son a tall loft bed. This will be at least six feet tall and will have uprights that are at least six feet tall, maybe longer.
I have some 3"x2" oak lengths that I plan to use but I need to plane them straight and square.
I have a small SIP 6" bench-top planer and a selection of planes including a Veritas bevel up jointer, Stanley #5 1/2 & #7.
Given the length of the pieces to straighten, I was wondering how to approach this.
I have had a think and have come up with these:
1. Use the SIP and try to use it as is.
2. Use the SIP and incorporate some roller stands for support.
3. Use a hand jointer and 'eyeball' it to check for flatness/straightness.
4. Use a hand jointer and use a homemade straightedge from a sheet of MDF to check.
5. Use a hand axe and call it 'rustic'. :wink:
I'm thinking that #1 is quite likely dangerous so I won't try that and I doubt SWMBO would let #5 into the house. I will probably opt for #4 or maybe try #2 and finish with #4.
How would others approach this?
Are there any other options?
I've never had to true-up anything this long before and was wondering if there was any special technique involved.
I was also wondering if #3 would produce a 'good enough' result bearing in mind that I need to mortice and tenon cross members between the uprights. Is it possible to get them straightish by eye and then fit the other parts to them? A sort of custom fit?
I've done a bit of searching on this and have come up short. It might be that my search skills are a lacking but I would like to get other's ideas on this.
TIA
TIA
