Andy Pullen
I have an Electra Beckum planer that I've owned from new, a decade or more.
Today I fired it up to thickness some timber and found that the power feed wasn't working.
I took off the side cover and found the flat rubber drive belt was being tossed off the wheel that it runs on. This belt connects directly to the cutter block shaft.
I managed to keep it on by using some belt dressing spray but it is making quite a buzzing noise when it runs and I'm not sure if it is the belt or the pulley at fault. I was wondering if anyone else has had this problem and what cured it.
When I think of it the machine was making a loud buzzing sound on starting for some time but it generally went away once the machine was running and I think this problem could be related.
All help appreciated.
