Planer blade size
jo-53
9 Feb 2012
salisbury
Hi,
I have nearly finished replacing the broken parts on my wadkin boas 12x7, and have just got to set the cutters. The set that were destroyed were 30mm x310mm x3mm, my spare set are 25 x310 x3 , which originally came with the machine. I found that the pair on the machine I have taken the parts from are only 20mm (310mm x3mm) and marked stanley, they seem quite thin for the slot and I am wondering if they are safe to use?
Any advice would be gratefully received.
Jo
cutting solutions
6 Jan 2010
Nr Soham Cambs
If the original blades should be 30 mm high then the 20 mm ones have been reground many times are probably not very safe. The back (bottom) of the knife will most likely be close to the bottom of the wedge if not part way up it.
New 310x30x3 from stock :wink:
jo-53
9 Feb 2012
salisbury
Thanks. My thoughts are that the blades are not correct for this machine, they don't appear to be old. But I suppose old or new, the wrong size is the wrong size.
Jo
Benchwayze
10 Mar 2007
West Muddylands
Jo
All I will say Jo is with planing machines:
Don't take chances, because you'll likely only get one; the last chance. :wink:
MickCheese
29 Sep 2006
High Wycombe, Bucks
Not wishing to hijack the thread but how far can you go with re-grinding blades?
Could it be that Jo's 30mm blades have been ground so many times they have lost 10mm?
Mick
Digit
11 Nov 2007
Wales
My experience with the older machines Mick is that the locking screws push downward slightly against the bar that secures the knife, beyond a certain point the bar will begin to tilt under the knife.
At that point the knives should have been replace earlier!
Roy.
