Hemsby
Need advice please,
My pillar drill has a single phase 1HP motor that I have just had rewound. The original plate on the motor states 2.8 amps full load.
All works well unless I change the belt for max speed and the switch trips #-o .
It is a MEM start/stop switch which has a sliding adjuster set at 2.8 amps, I assume it is an overload setting :?: not sure if it has accidentally been moved during the machine overhaul.
Is the motor max of 2.8 amps too close to the overload setting of 2.8 amps :?: Should I change it to next setting of 3.1 amps or leave alone and assume there may be a problem with the rewind (unlikely) and call in a man who knows :?:
Thank you
Thank you
