Patina - and where to buy it?
kevinr
13 Jul 2006
southend-on-sea
A lot of people seem to have had good results with Patina.
Am I correct in thinking it goes on easily and gives a tough finish?
I need to put a finish on an under-desk storage cart in Pine veneered MDF
and a Pine fire surround (that I spent ages sanding back from gastly).
We favour a low sheen clear finish and it sounds like Patina does this easily.
What do you think?
Also - where can I buy it or something equivalent. Getting very few hits on the web.
If you've got a Brewers near you they stock it. I've used it on a reclaimed beech school table which has had its legs shortened. It gives a nice finish but I haven't found it very good at heat resistance. I put three coats on but have had problems with heat rings from cups of tea. Perhaps I should have put more coats on?
Hope this helps
Philly":1krrtgvs said:
Didn't Screwfix used to sell Patina?
Thought they'd stopped stocking it?
Worth double checking though, as their catalogue has constantly moving product lines.
Adam
I couldn't find it on screwfix - probably didn't sell enough - its not pushed as a mass market product. Nor did I find it on the other large sites eg. toolstation.
Have you guys found it as good to use as I thought I read?
Somehthing similar is Osmo PolyX-Oil which I used recently on my Elm Chest. Available from here and they also do little taster pots so you can try before you buy. Good stuff - Rob
