Panel moving device
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
I regularly have to move largish panels. up to 6' tall and 12' long.
So a little while ago I produced this device.
Some times I need to move them across the yard.
On a windy day this can be exciting. :)
I can't quite figure out how to add some side support without turning it into a lorry.
I suppose a panel trolley would be the answer, but it's bulky
What sheets are they.....they are bigger than MFC.
When you say 'side support' how tall do you mean?
Enough to stop the sheets getting blown off the support beam or one foot, two feet high supports?
That might be the answer would afford some side support. A metal one could be left outside.
The panels are around 60mm thick
Enough to stop the sheets getting blown off the support beam although I suppose it would need a reasonably wide wheelbase otherwise the whole thing could tip.
This is mine, from one end. The other end is the same.
It's prettier from the side, as the wheels are borrowed from a balance bike.
Am I right in deducing, that yours is the deluxe self locking model as opposed to my bog standard one?
Yes, mine is self locking, and inspired by a Roy Underhill episode showing alternatives to a bench vise.
I built it specifically to transport 8 by 4 sheets of OSB for my shed build, which is 60 metres from delivery point, and is mostly gravel or long grass.
I have so far moved about 20 sheets of 11mm OSB, and about 8 sheets of 18mm. Once I've shifted the remaining 6 sheets of 18mm, the grandson can have the balance bike back.
Increase the wheelbase and add a couple of triangular supports in line with the axles to hold the panel(s)
These have been available for some time, including the smaller commercial models which are effectively a single skateboard truck with a middle support. This version is closer to the designs above and a compromise in sheet support, a small one but a step up at least;
https://www.bigdug.co.uk/handling-l...Ng394FLcCLM0Bn11hJFn1yCAB2fIFIdBoC5qUQAvD_BwE
Personally I find the grab hooks more effective but can see the benefit of the above if the ground is reasonable and it's not windy.
Edit: Just to add, Dewalt do one with side support if you wanted to get ideas for further support;
https://www.bigdug.co.uk/handling-l...ers-c359/dewalt-sheet-material-trolley-p20131
