pallets utility storage finished,but need quick help
Greek Enigma
21 Aug 2010
berkshire
hi i quickly went out n finished making some storage units for my mum today out of old pallets (no rain :) )
as you all know i know nothing about wood so here goes,
i finished making it my way today
but heres my issue
i'm thinking i should of put a back support/brace on? as has a lil play left to right on them especially the longer one
if so which one of these that i've drawn?
An 'X' shaped double brace would be best, but then you would need to joint them together flat where they pass one another.
The easiest thing to do would be to cover to back with thin ply - tacked around the edges.
haven't got any lol
couldn't i just use a straight bit of pallet?
if not guess il have to buy some ply
(it'll look like a cheap argos bookcase then lol)
nway do you recon i could get away with not putting anything on the back (no brace?)
I'd put 4 diagonal braces on - one on each corner. Each brace roughly half way along the shelf to half way along the upright pieces, that way you avoid having to overlap them.
Cheers :wink:
Paul
Cheers :wink:
Paul
so you mean a x but 4 pieces is that correct (i think i get you?)
ps do i really need to put anything on the back
as i got a feeling they might be ok as they are
as i so want to fill them up right now lol
what do you think?
Dibs-h":wyqlp5vz said:
You could use wire - steel wire could be ok. Or even some nylon rope.
omg that sounds crazy lol
i think ill skip that
well would it be ok with doing nothing to the back???
or shouild i just go buy some ply?
or would a diagonal be ok? as i dnt want to do a x
ummmm as i was a lil lost on the help that paul gave
No, not an 'x'. What I meant was that the braces are arranged so that each corner is a triangle.
Hope that's a bit clearer.
Cheers :wink:
Paul
I'll second Pauls idea.
Used to have some wooden racks at work that actes as a display stand for plant bulbs instore. They looked a lot like your stands. They too had 4 corner braces in the outer corners. I think that the longer the brace across the corners, the more racking they'll stand up to.
A full pallet plank should do it provided you can nail/screw it into a decent point.
No, like this
Cheers :wink:
Paul
Paul Chapman":1wcgyd3o said:
No, like this
Cheers :wink:
Paul
now i get what you meant about the lil triangles
ill defenetly do this tomorrow
as i'm guessing it'll add alot of support/strengh?
can i use screws as i'm out of nails?
and do i have to make sure i screw into the uprights or will just screwing into the shelfs be ok?
thanks for your help
Hi GE
Just use screws but make sure you drill a pilot hole first as it might split the wood otherwise. Use a drill that is the same diameter as the body of the screw without the thread or sightly smaller. Try one first and make sure it holds tight without splitting then you have the correct hole size.
Jim
Screws will be OK. Screw to both the shelves and the uprights otherwise it won't work. Should make it very strong and stop all the racking.
Good luck :wink:
Paul
jimi43":1jfp2n22 said:
Hi GE
Jim
i'm not that stupid (i always do this method myfriend)
i always pilot drill unless its mdf
and umm i always hold my drill piece near the screw and make sure its a li'l smaller that the screw aka the body of the screw (its common sense)
but thanks anyway,but i did know this
(not being rude :p )
Good luck :wink:
Paul
thank you
will do this tomorrow
if England doesn't rain :roll:
