Painting lots of wood
Charlotte
16 Jan 2009
Kingston, London/Gloucestershire
I'm currently painting my kitchen which has t&g and plywood walls (it's a boat). At the moment I've applied one coat of Ronseal primer/undercoat/knotting. The grain on the ply is still quite visible...is there anything that I can apply at this stage to fill it?
Charly
you could apply an oil based primer called zinnser coverstain then wait a day knock it back with 180 grit then re-apply another coat then you should havbe a brillant base for either a water based or oil based top coat sytem
