I need to make some big workshop cupboards (ballpark 6ft wide 8ft high 2ft deep) to store my power tools and everything else in the workshop to keep it clean (dust control is work in progress at the moment). In an ideal world (not where my wallet lives) I would use 18mm birch ply, but thats not going to happen at over £50 a sheet. OSB and chipboard are considerably cheaper but can it be successfully grooved for the shelves like ply can or can I just biscuit everything. Do biscuits work in OSB, I know care is need in chipboard or they bulge the surface. Also shelf stiffness may be a problem, whats a reasonable span for different loads and thicknesses (I know - how long is a piece of string), a single central vertical divider would give 3ft spans. Or should I make box section shelves with thinner surfaces top and bottom over a frame. It needs to be a relatively quick build, as time is even shorter than money. They don't need to be Chippendale but I do like things to be reasonably pleasing on the eye.
Any advice on these points or alternative ways of making these cupboards gratefully accepted.
Melv
Melv
