Carlneedshelp
Hi guys
Just doing some measurements for wood that I need to order. It is for wardrobe carcass. The wardrobe will have two sections which I will assemble before slotting them in place between the frame I have fitted to the wall. One section is for shelving and the other is for hanging rails.
The shelves will be 35cm wide so with the 1.8mm sides the shelving section will be 38.6cm. The hanging section will be 75.8cm wide so with the sides it will be 79.4cm. Both together make 118cm which is exactly the space available in the frame.
My question is, would you order the wood so that there was a few mm space to make it easier to slide into the space?
Carl
Carl
